Displays the XNV feature configuration and the authenticated VM information.
N/A.
None.
The following command displays the XNV configuration and the authenticated VMs:
* Switch.51 # sh vm-tracking ----------------------------------------------------------- VM Tracking Global Configuration ----------------------------------------------------------- VM Tracking : Enabled VM Tracking authentication order: nms vm-map local VM Tracking nms reauth period : 0 (Re-authentication disabled) VM Tracking blackhole policy : none ----------------------------------------------------------- Port : 1:20 VM TRACKING : ENABLED Flags MAC APC IP Address Type Value -------------------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------------------- 00:00:00:00:00:11 LBI 255.255.255.255 VM VPP lvpp1 IEP EEP 00:00:00:00:00:12 --- VM VPP IEP EEP 00:00:00:00:00:13 V--- 30.30.30.30 VM VMware-VM#2 VPP nvpp1 IEP a1.pol EEP a2.pol -------------------------------------------------------------------------------------------------------- Flags : (A)uthenticated : L - Local, N - NMS, V - VMMAP (P)olicy Applied : B - All Ingress and Egress, E - All Egress, I - All Ingress (C)counter Installed: B - Both Ingress and Egress, E - Egress, I - Ingress Type : IEP - Ingress Error Policies EEP - Egress Error Policies Number of Network VMs Authenticated: 1 Number of Local VMs Authenticated : 1 Number of VMs Authenticated : 2
This command was first available in ExtremeXOS 12.5.
